Fairing restoration/modifications...
Bassdude404
Rolling Prairie Indiana
Over the past 3 or 4 months I've filled in the holes for the snaps by the left fairing pocket, filled in the cigarette lighter hole, and made a new set of lids out of fiberglass...Before winterizing two of our other bikes and rearranging the garage to "winter mode", I shot the lids with a texture product and paint...I used SEM texture in an aerosol can and their satin trim paint...I was of course hoping for the best, but also apprehensive it would be what I wanted....
As you'll see in the pics. It turned out great!!!....
Great work and thanks for the post. I have heavily modified a fairing to fit my VN1600 Vulcan, lots of ABS plastic work that needs a facotry looking finish. In the past I wiped the surface down with Aceton and then coated it with brush on pickup bed liner material to get a consistent surface. But your results look better so I'll try that for my project.
I have also made repairs and new parts using a composite buildup methpd. I use perforated aluminum sheet stock (easy to find at Home Depot/Lowes/ACE) which is easy to cut and shape to provide a form which can be layed in fibergkas. I cut and form the aluminum and then cover one side with masking tape, then apply fibreglass to the other side. Once that sets I take off the tape and apply fiberglas to the first side. It creates a slightly flexible but strong composite layup to which its easy to install a latch or lock system or hinge. I used this method to repair a fire damaged Hannigan fibreglas faring, and to form the pocket cover panels.
