Vetter mount on a CB1100
husky385
Eugene Oregon
If I reconfigured the mount to bolt on the back side of the down tubes would that be strong enough to be a viable way to mount it? I don't think it would matter, but could be wrong.
The front side of the down tubes has the oil cooler in the way. I know carguy1959 moved his oil cooler to the outside of the mount. I would just as soon not move it.
Kevin
Since most of these mounts are only held on by hose clamps, I wouldn't see why not. If necessary, could you also run a support down below the cooler for added strength?
I thought it would be okay. Also doing it that way it would have to made in at least two pieces. I bought a mount from Ebay 1976 GL1000 to get some ideas.
Kevin
Hello Husky, after further investigation, I think the mount I used on my 14 CB1100 is from a mid late 70's CB750. I found some on eBay that look almost exactly like mine. I have put a better fairing on my bike and found some lowers that had the same pattern. Here is a recent picture.
Now that new fairing makes your bike look fantastic.
I had ordered a goldwing fairing mount off Ebay, the dufface sent one for either a Suzuki or a Kawasaki.
I have one coming for a 79 750 now.
I know you moved your oil cooler did you do any modification to the frame? I was thinking of moving the the upper mount to the back side of the down tubes to keep from altering the frame. What do you think?
Kevin
Just curious, are you a member on the CB1100 forum? Basically I measured everything (about 20 times). Then I removed head light, turn signals, oil cooler from motor. Than I worked on the bracket until it fit, flairing out the mounts, I had to trim the one that is long on top. I tried to make sure I had it as high on the frame as possible. Never did I cut or alter the bikes frame. Once I had the bracket mounted I turned the fork to full tilt each way. Then trimmed the braket until the forks didn't hit. When you get that far you will know what I am talking about. After that, I put the oil cooler back on and mounted to the bracket. Easiest thing to do for me. Then I mounted the fairing, had to trim the bottom a bit, no shimming needed. I used the factory head light from the 14 and made it fit in the factory housing of the fairing.
There is also about 10 other things I had to do, measure both sides of the bracket and make sure it is even in the back and front on both sides.
Also the bracket for the gauges had to be bent forward a bit to clear the fairing, this wasn't a big deal.
Yes Carguy I am a member of the CB1100 forum. I use the same username on all the forums that I am a member.
Thank you for the detail on what you did to make the mount fit, I have a mental picture on what you did.
Larry those pictures are literally worth a thousand words. I believe I have enough ammo to make this work.
This is the fairing that will go on it'
