trying to mount VETTER trunk to a 79 KZ1300...NEED HARDWARE HELP Ya'll
Harleychuck1
I BELIEVE ITS THE HARDEST PART IN THE WORLD TO FIND NEXT TO A BRAKE MASTER CYLINDER ON THIS PARTICULAR MODEL...BIKE HAS BAGS ALREADY BUT WANT TO ADD THE TRUNK.
THANKS:chopper
See framework attached to trunk in pic ..
This I SEEK ..
THX
The luggage rack in the picture is made by K&G enterprises. They show up on evil-bay quite often. The problem is the cost for the condition that they are usually in. The good thing is, they are pretty much universal.
Welcome to the forum!
Thx B.
I'll Chk center to center measurements as well as width and post them by Monday....
The tubes are adjustable and there is a set screw that locks them in place. That is the little dimple that you see sticking out the bottom about 3 inches forward of the bend. To adjust the width, you need to loosen two bolts and spread the side tubes apart and then tighten the two bolts again.
The one I have on my GL1200 is spread almost as wide as it gets, and stretched almost as long as it gets and I can still safely lift on it to get the bike on the center stand.
Brian,
Do you know where to find a cycle sounds dash pod???
Type "Vetter" into ebay and see what comes up... Several listed from $100 of less. I can't say I would pay $100 for one though. :eek:
This is the one I've been looking for...
It is not a cycle sound enclosure, but I want to install a stereo inside it. Six years and counting and never seen one for sale yet.
Just wait... Tom will throw some salt in my wound and post a picture of his! :D
I nearly bought one, an empty instrument shell, but complete with front plate. The seller tried to gouge me for postage though, and he went all quiet when I pointed it out.
Uh huh
I believe the above is for later year ...
79 needs this.
See attached.
2 radius bars hold trunk that connect to luggage hardware....
I stand corrected
View attachment 2137 Uh huh
79 needs this.
See attached.
I stand corrected
Hi there Chuck, I don't suppose you have an image of the top box mounting brackets? Am I correct in assuming the slotted bracket left of pic is what fixes to underside of top box?
