Headlight help
rob.lafady
Longview, WA
Hello everyone! Today's question is as follows, what I know I have - a windjammer ss with a sealed lamp. What I want - a way to run an h4/led headlight. Anyone know what all I need to buy to do it? I know halogen lamps were an option and I've seen guys talking about converting those to led. Thanks in advance for any help!
I see you have a '78 GL1000. The headlights on the Windjammers are the same size (7") as OEM on the early GL's (at least the 1000's and 1100's.) If you still had the OEM headlight, in '78 they were H4. Odds are against that still being with the bike though. Looking on-line the OEM H4 headlights are still available, but I'd search for used first.
So far as taking that to LED, I have no knowledge or information. Sorry.
Funny, I looked up motorcycle H4 headlights and the price was around $100, I checked out 7" H4 headlights for cars and the price was around $20...
Not a headlight expert, but as I understand it, automotive lenses point low beam off to the right, motorcycle lenses do not. That said, right wrong or indifferent I have read of people using automotive headlights on motorcycles, but I have to advise not to. I'm sure they are different for a reason.
I sure don't see $80 difference in their construction!
Bearing in mind I'm driving on the other side of the road from you...
I've always found a car 7" H4 headlight to be fine on a bike. When I dip for oncoming traffic, I still have a kick-up of light to the left which illuminates the ditch and hedges, and in the countryside that's a good thing (those of you in deer-infested lands will know what I mean).
When cornering left, the kick-up is very useful, and when cornering right, I'm on the left side of the road, so the normal dip pattern illuminates far enough ahead around the bend anyway. I simply adjust the main cut-off to be as high as reasonably possible without causing any glare problems to other drivers. Even the flat-dip motorcycle headlamp cannot address that problem - it's always a compromise.
Personally, I think the motorcycle approved totally flat dip pattern is just a cop-out by the makers, so they can fit a worldwide headlight unit that's not sided for any particular market and it's cheaper for them. A flat-dip pattern isn't going to give any bend illumination on the left or right, so I don't see the point.
To get the best result, not just any old light unit will do, as there are some dreadful ones out there. I'm now using a Koito 7", which has a very usefully even spread of light without any distracting hot or dark spots.
These were fitted to Mitsubishi Shoguns and Pajeros in the late 80s / early 90s. There are plenty out there, for cheap, and you'd be hard pushed to find a better one for the money.
I've read good reports of the Autopal units, and as far as I know, they are copies of the Hella lamps of the 70s, which weren't bad. The Autopal factory seems to have done a good job of reproducing them.
I nearly bought Lucas or Wipac units, but was lucky enough to find a few Hella H4 units cheap. They're also pretty good. I'll be fitting them as my auxiliary lights, with LEDs in them to lessen the alternator load.
