Well, I'm doing it! I cut out the lower section of the bracket, coated the cut ends with liquid rubber, contact-cemented rubber pads (cut from a hose) to the saddles for spacing and friction, and clamped them onto the bike's frame with two hose clamps per saddle.
The bracket is rock solid, and the WJ5 fits on the bike and looks great, but I haven't fastened the WJ to the bracket permanently. I need to fashion a pair of wedges, about 1" thick at the rear, and longer bolts to place the angle of the windshield parallel with the fork tubes.
I'm thinking of making a simple pair of wedges out of a wood 2x2 (actual size 1.5" sq), and painting them black. I'm also thinking a hollow black plastic square tube of some sort might be lighter. Please check out the attached thumbs and let me know what you think so far.
