Updated the theme, they have added a ton of new features and some bug fixes. If you see anything weird please let me know.
- Category description tooltip
- Jump to top fade (turned off by default, will not fade out - some people wanted this feature so it has been built!)
- Rounded Online Indicator
- Pulsating Online Indicator (will do a cool little pulsar effect, can be disabled of course)
- We moved uix.css to be included after the last css file is called in the main include. This saves you a resource call.
- We moved fontAwesome above all JS, thus making your page load a bit faster
- Added <xen:hook> to the footer columns so you can now use widgets instead of static html (ie: hook:uix_footer_col1 for widget framework)
- Login with facebook text was discolored, we made the text white
- New label added so it can display 'New' next to a node. Great if you want to remove the node icons altogether and save space.
- Made the staff banner pull from tertiary color, more prominent than gray
- You can now add a favicon via a style property
- Side by side categories now is fully functional (node style 2)
- We completely reorganized the style properties so they are more intuitively named, better descriptions, and in proper order -- should be easier to find things! Should flow like a river of butter!
- Can hide footer menu (home/privacy policy/top/contact/etc), great if you want to just the extended footer instead.
- Move all private postbit message controls to a dropdown menu, great for consolidating the postbit. Turned on by default
- Center the postbit message controls at a certain width, you choose.
- We made some optimization improvements for those looking for quicker load time. We did all we could think of. If you have suggestions we are entirely open.
- More control on how you size the call to action next to breadcrumb
- Vast improvements to the posts layouts and postbit
- Avatar issues, this has all been fixed and is fantastic. We turned the retain avatar dimensions off by default, but you should check this feature out. Those that want full size avatars can do so without any template edits
- Center logo bug where you could not have it all the time centered has been fixed, you enter 100% now.
- Firefox and IE footer blocks now stack properly, this has never been reported to us strangely enough but they now stack wonderfully like they do on chrome.
- Prefix border fixed
