Does anyone have some images of a Windjammer 4 mounting bracket on a Suzuki GS850 1979.
Thanks, nice Pics Larry your Bike looks Awsum.You can get an idea of what you're looking for in my WJ install thread. I put a WJ bracket from an '82 CB750C on my '96 Nighthawk 750:
The WJ5 is going on the Nighthawk after all!
Thanks, will do.Explore the Craig Vetter site. There is a lot of information: https://www.craigvetter.com/
I do not know whether sales are still open, so confirm before sending any money.
Thanks Larry, I will get rid of it then.That is not a Vetter item. It looks home-made.
I have a WJ4 mounted on an 80 GS1000G, which I believe is the same frame as yours. I bought the bike new and installed the fairing at that time. That was 42 years ago, so this is the best I remember. The headlight brackets have to be taken off. All the wiring connections in the headlamp was gathered together in a bag. All the connections to the fairing are to a special connector, which I hope you have! The bracket is installed first with U-clamps and hose clamps. If you need dimensions or photos of the bracket, let me know. I could get no help at several dealers regarding the carburetors and other items. By chance, I found the mechanic that worked at the dealer when I bought the bike. He is almost as old as I am! I know he set the carbs much richer then original. The bike doesn’t get as good as mileage, but runs much better. Get somebody to install new fork springs and get rid of the air assist. Constant leaking seals over the years. I would suggest changing the rectifier to a different type. Made a big difference in voltage and oil temperature. Below is some of the text from “ GSRESOURCES.COM “. Good luck my friend. GreggThanks Dave.
Nice Pics. Cool
To mount the windjammer fairing, do you have to dismount the forks and the front wheel or not.
I am new on this.
I'm curious about it now. I would like to take it off of your hands for the cost of shipping if you're willing..Thanks Larry, I will get rid of it then.
#2 The Series-type Compufire R/R CF55402
(only part number applicable to 3 phase PM alternators like GS Suzuki)
The Compufire is my favorite as it is the smallest Series-type R/R available here in the US and is a MOSFET Series-type design which results in slightly superior performance to the SH-775 in terms of lower power dissipation, higher (low RPM) output voltage and lower OFF state current draw. General results should apply to any Series-type R/R not just the Compufire.Thanks GI have a WJ4 mounted on an 80 GS1000G, which I believe is the same frame as yours. I bought the bike new and installed the fairing at that time. That was 42 years ago, so this is the best I remember. The headlight brackets have to be taken off. All the wiring connections in the headlamp was gathered together in a bag. All the connections to the fairing are to a special connector, which I hope you have! The bracket is installed first with U-clamps and hose clamps. If you need dimensions or photos of the bracket, let me know. I could get no help at several dealers regarding the carburetors and other items. By chance, I found the mechanic that worked at the dealer when I bought the bike. He is almost as old as I am! I know he set the carbs much richer then original. The bike doesn’t get as good as mileage, but runs much better. Get somebody to install new fork springs and get rid of the air assist. Constant leaking seals over the years. I would suggest changing the rectifier to a different type. Made a big difference in voltage and oil temperature. Below is some of the text from “ GSRESOURCES.COM “. Good luck my friend. Gregg
Thanks Gregg, you gave me a good advice, experience and more credible viewpoint, I am new on thisI have a WJ4 mounted on an 80 GS1000G, which I believe is the same frame as yours. I bought the bike new and installed the fairing at that time. That was 42 years ago, so this is the best I remember. The headlight brackets have to be taken off. All the wiring connections in the headlamp was gathered together in a bag. All the connections to the fairing are to a special connector, which I hope you have! The bracket is installed first with U-clamps and hose clamps. If you need dimensions or photos of the bracket, let me know. I could get no help at several dealers regarding the carburetors and other items. By chance, I found the mechanic that worked at the dealer when I bought the bike. He is almost as old as I am! I know he set the carbs much richer then original. The bike doesn’t get as good as mileage, but runs much better. Get somebody to install new fork springs and get rid of the air assist. Constant leaking seals over the years. I would suggest changing the rectifier to a different type. Made a big difference in voltage and oil temperature. Below is some of the text from “ GSRESOURCES.COM “. Good luck my friend. Gregg
Yes my bike looks similar to yours and i just purchased some lowers mounting kit and a 9 pin plug set from the store it arrived on Monday so i am ok with the wiring connections.
When I ordered my lowers kit, even though is specifically for my/ our bike, it did fit at all. The lower is a 2 part assembly. As I understand it, the shiny side is the same for all variants. The inner part is not! I had to do a lot of cutting and fitting to make it work. Also, I take mine off during the hot part of summer.Thanks Gregg, you gave me a good advice, experience and more credible viewpoint, I am new on this.
Yes my bike looks similar to yours and i just purchased some lowers mounting kit and a 9 pin plug set from the store it arrived on Monday so i am ok with the wiring connections. I will be checking the rest that you mentioned. Thanks
