Windbüchse
Have the Vetter trunk mounted. We'll give it a test ride tomorrow. I modified a Saddleman seat so the trunk is attached to the seatpan and the standoffs aft of the seat attachment bolts. It is easily removed with 4 bolts and the wire connector. I will only wire the brake and running lights using aftermarket LED light units (on order). The back cushion attaches with 2 studs and can be repositioned. I've made accommodation to allow fore-aft and tilt adjustments. After sorting the ergonomics, I'll place a gel insert onto the foam to raise the ride height 1" and move the rear edge of the seat an inch back.
Is there a simple way to lower the pegs 1 - 1.5" ? That would be more helpful than raising the seat.....
Thanx, Martin
Thanx, Martin
